Oil Pressure High
Oil Pressure High
Postby NCKidd16 » Fri Aug 06, 2010 10:54 am
Just rebuilt my 2.6 in my 88 ram 50 and it runs fine. But the oil press. Is about 35-40 psi idling and almost 100 running 60 mph turning about 2300 rpms. Is this normal oil pressure for these motors?
88 Ram 50 4wd, Rebuilt G54b 08/10, 30x9.50 bfg a/t,
NCKidd16
Engine Size: 2.6
Re: Oil Pressure High
Postby 83L200 » Sat Aug 07, 2010 1:02 pm
my 4g63 runs those pressures if thats any help
83L200
Engine Size: 4G63
Postby NCKidd16 » Sat Aug 07, 2010 3:04 pm
Has it always ran those pressure. Its almost peggin my gauge cruising. I have heard that to high of oil press will blow the oil filter off. But idk? Any info would be helpful. Thanks
NCKidd16
Engine Size: 2.6
Postby 83L200 » Sat Aug 07, 2010 10:43 pm
its always ran that high
83L200
Engine Size: 4G63
Postby D50DAVE » Sat Aug 07, 2010 11:57 pm
Mine has always run a little over half on the gauge. Pegged is a little high. Probably won't be any problem in the near future, long term who knows. When you rebuilt did you use the same oil pump?
D50DAVE
Postby NCKidd16 » Sun Aug 08, 2010 7:08 pm
Thanks for the replys guys. No I used the new pump that came with my rebuild kit. Other than replacing everything the only thing I changed was I installed a balance shaft elmination kit. But I wouldn't think that would effect it.
NCKidd16
Engine Size: 2.6
